This is already my 3th question this month. Went to the dealers today, to check if they finished servicing my TT and if they discovered something new about my AUQ 225 TT (engine was probably rebuilt, all of the other parts are from APX except for the engine head). They started working on it when I came there, so I stayed for 3-4 hours to watch them work (gearbox oil, brake fluid, cambelt, water pump, tensioneer(s), haldex, driver's window repair, sump, engine compression check). They started with sump, then moved on to the cambelt, water pump and tensioneer, but as one tensioneer was missing (there should be two tensioneers, but I don't know how are the called in english), they stopped working on the engine and moved on to the haldex. They changed the haldex oil, but when I asked them about the filter, they told me that the filter doesn't need to be changed and is not part of the usual service?
Well anyways, they've run out of time and will continue their work tommorow. I'm sure that the mechanic working on my car had no idea of how to change the filter. What should I do? There will be someone else working on it tommorow as it's Saturday and they are only finishing the work that they've started today.
