1 - 7 of 7 Posts
Anyone encountered a problem with this not running when it should ? The pump itself is OK - hooked it up to 12V and it ran fine - but I don't think it is running from the controls. Does it have a separate fuse and what could have caused it to blow?
Headlamp washers only work if headlamps are on and you pull back the washer stalk for at least 2 seconds - did you do this when testing?
Had same problem. Needed to replace the large brown relay under the dash (drivers side).
Passed MOT all working.
Quite an easy job just drop lower dash panel to access, then plug and play.
Hope this helps. :lol:
1 - 7 of 7 Posts
