1 - 8 of 8 Posts
just bought an audi tt 225 quattro
drives fine on long runs runs 75 ect (i know should be 90)
but in traffic will go to 110 ect,
my ac is very cold wen the aircon light is off? confusing not sure if its ment to,, nd blows war air wen lights on (no t sure if related)
also last week wen warm was reving the engine testing a new d/v it was hot nd suddenly the engine squirted at me (water) any one had this before?
the car has perefect audi history pumps been done ect so i should think its not that??? also the fuses in the battery tray is ok so any help??? pleasee :( dont want to find out tht its going to cost me hundreads ha
thanks
Hi Boo, Looks as if you have 2 probs, thermostat & fans not running at high temps.
Where are you getting the temperature readings from ?
Aircon/Climate control will blow cold air if temperature is set low, Left hand switch pushed in, Air/CC is on, raise temp by rotating switch clockwise.
water came from a pipe close to fan (recon it was too much pressure due to heat ect,, my theory)
right ill order the fan switch and also a thermostat
thi should help im hoping
ye i been thinking tht the economy button was the air con,,,, i really do feel stupid now :(
That's OK... It was weeks before I knew that my seat warmers weren't really broken... I had no idea that the buttons turned until I saw a picture of someone's dash with the lights lit up.
Good link that matey, I didn't know about the knobs turning either 8)
1 - 8 of 8 Posts
