selling my set up as no longer have a 4wd set up in my mk2 g60 syncro..good for 450..
spec as follows..
bam botttom end .5 over bore ( small bore 1.9)
je forged + de comp pistons 8.3.1
corrilo forged rods
dynamicly balanced crank
all new oil pump .cam chain .etc
euro spec bearings through out
apr retaining bolts
large port audi a6 head aem code. inlet side flowed and match ported to the arp motorsport inlet manifold
arp motorsport inlet plenium( massive/balanced air / boost balance delivery )
r32 throttle body ( brand new)with custom made boost pipe work to fit and reduce etc .....made by rs tunning ..
std bam sump
cam belt and tensioner etc all new too..
may split .....i am after 1900 for the set up....or prices will vary if split
dale 07756392332
as i say insp welcome
spec as follows..
corrilo forged rods
apr retaining bolts
std bam sump
dale 07756392332
