nothing 😭Hi, Not a clue.
Close drivers door, Remove both battery cables, touch them both together + to -, and then reconnect cables to battery.
Hoggy.![]()
Just tried that nothingHi, Can you move/push the TT to another position, thinking something in the area is blocking the immob signal.
Otherwise out of suggestions
Hoggy.![]()
I’ve got jumper van on it and I’ve tried the battery thing for 30secs no joy so must be the clusterHi, Try the battery disconnect again & hold cables together for a good 20 secs. Drivers door closed when you reconnect to battery.
Have you checked the battery volts?
Hoggy.![]()
I’ve never heard of that one before??Or the immobiliser coil in the steering column. I’ve heard that’s also a common point of failure.
1 as the other lost it’s program sitting there with a new chipHow many keys do you have
Oh I see the transponder inside the keyIt's the little glass tube, try removing it, and taping it to the ring?
Sad face.. are you getting a mate to toe you tomorrow?Car battery dead now And no tow trucks want to come out for less that £200
