allewijn said:
Okay, I vagcommed it, with this fault:
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
01155 - Clutch
04-00 - Mechanical Malfunction
So indeed, the haldex isn't working I think.
What's wrong?
unfortunately of the two types of fault this is the worst to get. by all means try the haldex and fluid change to fix it its worth a go!
But DONT assume its cured because the fault doesnt return, it needs certain conditions to test it.
The Haldex controller faults are easy to register because the electronics either fail, or they operate their mechanical parts and measure they work and if the dont, you'll get a Haldex controller type of failure or haldex memory fault.
The fault you have above occurs because the controller has done its job, the input from the Rear ABS rings has detected a massive difference in wheel speeds between the front and rear wheels and therefore the HALDEX DIF itself is considered non-functional with a mechanical failure!
Appreciate in most dry conditions you may get enough traction to have little difference in front and rear wheels so your fault may not return.
Ideal conditions to test ( or force ) this mechanical fault is to try and launch the car on a very wet surface to ensure you exaggerate the front wheel slip against the rear wheels to ensure the fault is cured.
if its still a problem you'd probably feel some front wheel scrabble but if not there should be minimal slip and a clean-ish take off. But try that a few times on wet ground and then check for faults.
