1 - 3 of 3 Posts
First it was the Xenon going, now brake light, now door sensor and indicators sometimes work sometimes don't, random flicking, but hazards work fine.
Also very hard to get any readings from the diagnostic ports? Knightmare!!
I have a 225Q 52'.
Would say just a combination of things. xeon ballasts are quite common, the hazord switch failing on indicators is also commong (it's the relay inside the hazord swithc) it's always seen to be a mith, but because the lights are switched by the same power supply it may reduce life of the rear tail light.. as i said it's a myth but seems to be a good coincidence all the same.. likewise with just changing one bulb instead of the pair of rears, a few weeks later the other side blows... :roll:
Coincidence definitely.
There is a good "how to fix it" re Hazard Relay (Indicators) on here. Also worth cleaning the indicator stalk.
BTW the indicator stalk is on the left of the steering wheel!!!!!!! (Just messing! :roll: )
1 - 3 of 3 Posts
