Done a log of my TTS. This is logged using IE logging tool. Stage 1. Does it look Ok.
datazap.me
datazap.me | geira | Log 1658072650
Looks ok to me but you should send to IE and they should be able to day for sure--their tune so they should know what #s you should be getting for boost, timing, etc.Nobody has an opinion?
Well it is, so they can't tell you what to change or modify ('cause you aren't DIYing) but someone should be able to point out things that don't look right or might be unsafe. I mean you'll have to have someone kind enough to take a look and help you out, but lots of people online do that kind of stuff so cross your fingers!i dont have high hope as Nefmoto is all about DIY![]()
Very happy with my IE [Stage 2] tuneYes. Hoping they can sort it out. Have heard that IE is a good tune
I logged it before yeah but I wasn't looking for the same thing you were looking for. I wasn't concerned about track durability I was looking for a problem that caused a stutter whenever releasing and re-applying the throttle at highway speed. That was a DV problem, which was nicely solved with another DV+.Good to hear you havent had any problems with the tune. Have you logged it ? . I dont have any problems either, but my log says that something funny is going on. Got a mail from IE yesterday and they say the file is tricky, so there has to be diffrence from other TTS ecu. Will see if they are able to fix it. Otherwise i might just stay stock.
