So just a little follow up story in case any of you are interested...
After posting this things went down hill fast...
When installing a custom turbo setup of course things are going to go wrong and they did! I had to modify the water line running to the turbo from the coolant reservoir. Luckily the banjo bolts that mitsubishi used on the 20g were the same size as the lines running to the k03 so everything bolted up well. I used a plastic coolant T from Autozone to tie the modified line into the old hoses. First MAJOR mistake...
In Audi's brilliance they use a reverse flow cooling system, so instead of coolant flowing from top to bottom in the radiator it comes from the bottom to the top so that it fills the entire radiator evenly which is Genius... I didn't know this when I hooked the coolant lines up, so the line I thought was going into the turbo was really coming out. So this SUPER heated coolant via SUPER HOT turbo was melting my coolant T. So I over heated on the freeway and warped my head...
I purchased a used AEB head and had it race ported and polished in hopes it would help spool the 20g, and it did! After the new head install I went for a nice saturday drive. The turbo went from max spool at 6000rpm down to 4000rpm! Unfortunately I was being dumb and did not get the car tuned... That night on the way home I was racing on the freeway and my check engine light flashed and I felt a cylinder drop. After pulling the head again I found that I burned 2 exhaust valves. I had the valve seats and valves replaced and reinstalled the head. This round I installed 4 Bosch Green Giant 440cc injectors. It ran very rich but I was ok with it since I was more concerned about burning a valve at this point, but the car ran horribly...
2 more times the coolant T broke after this and I warped my head both times. Right before the last time I warped the head I went to get my car tuned finally and spent a grand on it... After the tune I found out that I had a lack of compression thanks to my piston rings loosing tension from overheating all the time... So the last time I putted around before it over heated again and I finally through in the towel...
Very expensive lesson I learned with that car... I could have spent $75 and replaced the plastic coolant T with a metal one. it would have saved thousands of dollars and a lot of heart ache. In the end I spent over $12k building that car and I did all the labor... What a waste...
