You should be able to remove the laptimer menu in VCDS. 17 - insruments. and i THINK it's in coding or adaptations. Ther'es a "special functions" menu where you enter in 1 or 0 toactivate/deactivate.It's the only downside for now, I know it can be fixed, just need to work it out. The whole lap timer screen can be coded out bit I've left it on for now, but you've probably gathered I'm a bit of a perfectionist and it annoys me that it is there, so it will be sorted at some point don't worry!
hi any guide available? ThanksGood news for OBDELEVEN and power folding mirrors.
You can do EEPROM coding with OBDELEVEN gen 2 (android only).
I managed to do it and it worked.
I will do some more testing tomorrow and if anybody interested I will post a guide.
Looking goodThankyou for pointing me in the right direction MT-V6.
You are definitely becoming the new rettroTTToday I managed to remove the boost gauge while maintaining the lap timer screen with the oil temperature. Everything works properly now, and the top line of the DIS just shows the radio info as on other screens
Thanks, all part of the fun. It's probably one of the highest spec TTs now, excluding mechanical modificationsamazing work @MT-V6 just spent some time reading through this whole thread lovin the OEM Plus mods cant wait to get my TT!
am I right in thinking there are 2 facelift timelines on the TT 2008 and 2010? please delete if in wrong threadThanks, all part of the fun. It's probably one of the highest spec TTs now, excluding mechanical modifications
To be clear, there's no way to add the boost gauge to a car that doesn't have it (but has the white/facelift cluster), right? Or did you do all this by actually uploading different s/w to the cluster? Just wondering if it can be added some how to a TT-S which doesn't have it but I think the answer is the same--you actually have to change the cluster software to do this?Today I managed to remove the boost gauge while maintaining the lap timer screen with the oil temperature. Everything works properly now, and the top line of the DIS just shows the radio info as on other screens
Now all you need is a cheeky ColourMFA upgrade @NidanaThankyou for pointing me in the right direction MT-V6.
Hi Ian - Can you do colour MFA on the red cluster or do you need white - ?Now all you need is a cheeky ColourMFA upgrade @Nidana![]()
