Can be installed on eitherHi Ian - Can you do colour MFA on the red cluster or do you need white - ?
That's the beauty.
1 second == 1000ms/100=10
10 == 0A
I've woken up to a sunburnt face today and had a good day my next visit I intend to run mine. It's not going to break any records except to put a big grin on my face like the one clearly in this photo. I will hook up with you so we can do some runs if you like at a later date won't be much in it really except the smile points. You did well on the other bit also when you consider the heavy lump in the front and the DSG box for the garage part. Do wish I had done the service that I've had lined up for Easter weekend earlier instead but never mind. Let me know if you are up for going again sometime and we can sort something out.I was at GTI Spring Fest yesterday and couldn't resist taking the TT on the drag strip. I ended up doing 4 sprints, my best time was 14.45 seconds @ 94.69mph. Unfortunately I was never up against anything too similar, was hoping for another TT or an R32 Golf
Oooh nice one!I was at GTI Spring Fest yesterday and couldn't resist taking the TT on the drag strip. I ended up doing 4 sprints, my best time was 14.45 seconds @ 94.69mph. Unfortunately I was never up against anything too similar, was hoping for another TT or an R32 Golf
I also found this to be the case where launch wouldn't "activate" each time. Do you remember what RPM yours sits at for launch? Mines just above 3k....And of course I used launch controlit worked very well 3 out of 4 runs.
Sorry I forgot to reply to this. Yes about the same as mine then, can't remember if it was 3000 or 3500I also found this to be the case where launch wouldn't "activate" each time. Do you remember what RPM yours sits at for launch? Mines just above 3k....
It's the small details which make it.Sorry I forgot to reply to this. Yes about the same as mine then, can't remember if it was 3000 or 3500
I have fitted LED front indicator bulbs. I like the instant on/off flashing but was always put off by bulb errors/resistors etc. However I came across a nice set by Philips. They do actually come with resistor modules but it turns out they are not needed which is nice. Quick video to show the comparison between the original and the LED
They are Philips 11498XUAXM for anyone interested. Note that the PY21W fitment is specific to the LED DRL xenons variation of the headlights
Kudos to your assistant. Unless it was you that stood in the rain while they sat in the car...Sorry I forgot to reply to this. Yes about the same as mine then, can't remember if it was 3000 or 3500
I've always wanted to change my fogs to something more matching the xenon lamps, even going back to 2013 when I got the A3 with them (my previous A3 didn't have xenons). But, I never did, lol. The main reason being...basically never use the fogs because they are manual. Unlike other cars I've had with auto headlights in the past, the fogs were able to be set and left so whenever the headlights came on, the fogs would come on. (Note it is perfectly legal to run fog lights when there is no fog/rain where I live, but I know this varies depending on where one is in the world.) But not so with VAG cars, you can't combine auto and fogs in any way--I even fooled around with every coding option I thought might do it but nope.Not the most interesting update but I swapped my fog light bulbs with some whiter ones that better match the LED DRLs when the coming/leaving home lights are active
In these photos I had swapped only the right side for comparison:
Less hassle than LEDs and the fading still works when unlocking and when the cornering lights are active. I used Philips WhiteVision ultra H11
Another option, (albeit a bit expensive) is bi-colored LEDs.TT'sRevenge said:snip-> every once in a while I get the inkling to buy LED fogs, but then there's just so many different ones out there, I just don't feel on researching what's what and what I should buyNice to see there are some standard halogen alternatives as well.
