I have swapped my LED bixenons for AFS LED bixenons. This is a kind of "upgrade" guide that can build on my main retrofit guide. I knew I was planning on going this route so I installed the correct wiring in advance, so if you have factory fit bixenons already fitted, you will need to run some extra wires to them. If going from halogen (like I did overall), still more wires will need to be run, read my other guide first. Some changes are required in the dash fuse box.
https://www.ttforum.co.uk/threads/my-phantom-black-v6-thread.1505602/page-2#post-9374517
Firstly, these parts are required:
AFS headlights x2 (RHD/LHD to suit your car) - will add part numbers
Ballasts (they differ) x2 - 8E0 941 329 A
Screws for ballasts (if ballasts are not already attached to the headlight unit) x6 - N 903 474 02
AFS module (in order of age, any should work) - 4F0 907 357 F -> 4L0 907 357 -> 4L0 907 357 B
Module connector - 7M3 972 726 A
The AFS headlights have satin silver on the sides of the projector, compared to the gloss black of the standard bixenons.
Here is the standard xenon module on the left, and the AFS one on the right. The blue connector is very slightly different, though the inner black pin holders are the same, so they do not need to be completely repinned.
The AFS module mounted up behind the instrument cluster after repinning. I unplugged the headlights before repinning this, as some power outputs differ and I didn't want to damage anything. I didn't reconnect them until the new module was in place.
You will get this error when you code AFS in the instrument cluster prior to reconnecting the AFS module.
The coding is:
10-Instruments
- Coding:
- ????xxx: Equipment
- +0032 = Advanced Front Lighting System (AFS = Cornering Lights) installed
55-Xenon Range
- Coding:
- 0000023 = Audi TT (8J) with Steel Suspension and Front Wheel Drive (FWD)
- 0000024 = Audi TT (8J) with Steel Suspension and All Wheel Drive (AWD)
- 0000025 = Audi TT (8J) with Magnetic Ride
Note: Perform Security Access before Coding and Basic Setting (Headlight Adjustment) after Coding
Security Access:
- 02000 = General Coding "Enabling"
- 02000 > 03000 > 04000 > 05000 = General Adaptation "Enabling" (Enter one after another)
http://wiki.ross-tech.com/wiki/index.php?title=Audi_TT_(8J)_Headlight_Aim_Control_(Adaptive_Light)
The pin changes from LED xenon to AFS xenon are:
Headlight pin 14, both sides > add new earth, 1mm2 brown wire
Module pin 6 (green/blue) > move to pin 21
Module pin 7 (blue) > move to pin 22
Module pin 10 (black) > move to pin 12
Module pin 12 (green/brown) > move to pin 10
Module pin 15 > Splice pin 15 (purple) and pin 17 (green) and move to pin 15 (green)
Module pin 17 > Splice pin 15 (purple) and pin 17 (green) and move to pin 15 (green)
IN PROGRESS
The headlight vertical height can be adjusted by the adjustor via this hole.
