1 - 9 of 9 Posts
So i got my first CEL today while i was casually driving. Here is a print out from all the modules the car is equipt with. i have found other codes buried in the control modules. they didnt drop any cel/mil but there appears to be a few problems. Any input relating to the engine module would be great. it was for bank 1 intake camshaft sensor i believe. ive deleted the modules with no faults to make it easier (and so it can fit in 1 message.)
also i always felt that there was something wrong with my bose speakers as they sound bad. there is faults related to speakers as well. any insight would be great.
There are codes related to rear left and rear right doors, im guessing because the cars a coupe that i can ignore these? :?:
Chassis Type: 1K0
Scan: 01 03 04 06 08 09 0F 14 15 16 17 19 20 22 25 37 42 44 46 47
52 55 56 65 77
VIN: XXXXXXXXXXXXXX Mileage: 90220km/56060miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
06-Seat Mem. Pass -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 1100
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 HF HW: 022 906 032 GP
Component: TT-3.2-HS-LEV2 G 1165
Revision: 1QH02--- Serial number: AUX7Z0H0FNA0A8
Coding: 0000172
Shop #: WSC 01236 785 00200
1 Fault Found
000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 12
Mileage: 85959 km
Time Indication: 0
Date: 2012.06.17
Time: 13:17:49
Freeze Frame:
RPM: 1746 /min
Load: 13.3 %
Speed: 45.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Component: J255 Klima 1 Zone 0080
Revision: 00H07004 Serial number: 00000001076215
Coding: 1048614
1 Fault Found
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 89035 km
Time Indication: 0
Date: 2012.07.17
Time: 15:16:21
Freeze Frame:
Voltage: 12.20 V
Temperature: 42.0°C
(no units): 47.0
(no units): 211.0
Temperature: 40.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007989921
Coding: F1061E83C0141C004F1800001800000000284E075A250802000000000000
Part No: 8J1 955 119 A
Component: Wischer AU354 H07 0070
Coding: 00064784
Shop #: WSC 01236
Part No: 4E0 910 557 B
Component: REGENLICHTSENSORH13 0100
Coding: 00149804
Shop #: WSC 01236
2 Faults Found
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 197
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:00
Freeze Frame:
ON
Voltage: 11.70 V
OFF
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J398)
Freeze Frame:
Fault Priority: 2
Reset counter: 197
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:00
Freeze Frame:
ON
Voltage: 11.70 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7G0220153
Coding: 0000102
1 Fault Found
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:17
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K0791981C8
Coding: E98B1F875007424102
Shop #: WSC 03285 999 59286
3 Faults Found
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:03
03395 - Control Module for High Beam Assistant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:03
01312 - Powertrain Data Bus
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 4
Reset counter: 218
Mileage: 84955 km
Time Indication: 0
Date: 2012.06.08
Time: 11:35:36
Address 37: Navigation Labels: None
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU US H06 0210
Revision: 0000012S Serial number: AUZBZ7LD400061
Coding: 0609675
Shop #: WSC 00493 128 20241
2 Faults Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:32
Freeze Frame:
Mileage: 84140 km
Count: 2805
Clock: 14:25
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:12
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0150
Revision: PROD_01 Serial number: 00000000002283
Coding: 0236116
3 Faults Found
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Reset counter: 237
Time Indication: 0
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Priority: 5
Reset counter: 237
Time Indication: 0
02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159)
Freeze Frame:
Fault Priority: 5
Reset counter: 237
Time Indication: 0
Address 56: Radio Labels: None
Coding: 0609675
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:32
Freeze Frame:
Mileage: 84140 km
Count: 2805
Clock: 14:25
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 117
Mileage: 84140 km
Time Indication: 0
Date: 2012.05.28
Time: 14:25:12
OK firstly id remove your VIN
RNS has been retro fitted based on the errors.
I'd also say you have a coding error or two. the BOSE things looks like one of two things - either the pin the has not been moved or, the coding for the radio is wrong.
TT cant have 06, and 0F so god knows who's been playing in the system. (id be very worried)
Also look like 20 shouldn't be there too.
Have you reset the errors and looked what pops backup?
i cleared the errors before posting. i drove around and the cel didnt return yet so thats good. i will scan again after 60km or so to see what returns. its possible some of it are old errors.
The only recoding that ive done to the car is related to the rnse. i did the retro fit myself, and moved the bose wire following direction here:
http://audiforum.us/threads/another-noo ... post-97753
i did not hook up a 32-pin connector as i dont really need aux-in. its possible the coding is not proper, 0609675 is what i was told to do for my car. its posted in the link above with the features i have. also im pretty confused about those errors related to parts not on my car. i guess i really need to re-scan and see what returned.
edit: i guess 0F is related to my coding sirius radio. there is a module in my trunk that says sirius on it, so i assumed i had it. is it possible its not hooked up properly to my rns-e?
edit2: is it possible that the vagcom software just scanned for that module and couldnt find it. i did an auto scan via vagcom so maybe that could explain it :?:
OK, I'm assuming you are US based, in which case you may have the wrong RNS-E unit fitted.
According to this list, originally posted by Toot3954, you have a European RNS-E unit (ends 193D), when you really want a US one (ends 193B or 193F). That would explain the Sirius Satellite Radio not working as the European units don't know Sirius exists, plus I'm guessing you have poor FM and AM radio reception as the receivers are set up slightly differently.
8J0 035 192 Europe
8J0 035 192 A Europe
8J0 035 192 B North America
8J0 035 192 J BNS 5.0
8J0 035 192 K BNS 5.0
8J0 035 192 L BNS 5.0
8J0 035 192 M Europe
8J0 035 192 N Europe
8J0 035 192 P North America
8J0 035 192 Q Europe
8J0 035 192 R Europe
8J0 035 192 S North America
8J0 035 192 P North America MY 2009
8J0 035 193 Europe MY 2009
8J0 035 193 A Europe MY 2010
8J0 035 193 B North America MY 2010
8J0 035 193 D Europe MY 2011
8J0 035 193 E Europe MY 2011, SDS
8J0 035 193 F North America MY 2011
Is the car remapped? or had the ECU swapped?
Having had a chance to go through the list of error codes I'd say the car has possibly had a remap from a file originally intended for an A4 sedan with the same engine and it's then been very crudely converted. I would have it flashed back to stock then take it to a reputable remapper (APR possibly) if you want it remapped again.
Like Toshiba, I would be extremely concerned that someone has been messing around inside the ECU.
thanks for the help so far. i bought the rns-e from ebay and it indicated that it has been re-coded for US market and will not work for EU cars. it was re coded and also i have the proper navigation dvd for maps and all of that is working great. So if the 193D doesnt work with sirius, do i simply code out sirius in my navigation coding so the unit doesnt try to to look for it? im guessing that would get rid of the codes related to sirius.i also dont listen to am/fm radio, so im not sure if the reception is bad.
the car was not chipped in my possession but who knows what the previous owner did. Im starting to think it was vagcom searching for a module that isnt there, so it just error out the module. i have a "free" version of the software, so its not up to date. not sure if that has anything to do with it.
anyone know what the engine fault was related to? faulty sensor on its way out? anyone know what sesnor?
also, anyone have any ideas what the faults related to the 3 speakers are? are these speakers blown and need to be replaced?
thanks again for the help so far. i will rescan sometime today hopefully if i have time and see what has returned. the main reason for the thread was the code related to the engine module so any info on that one would be great
cheers
VAGCOM searches all the HEX addresses - but talks only to what it can find.
So someone at some point has told CANBUS (19) that memory seats and HBA are present - and they are not. You need to remove the setting for both (check HBA - this is an option on the TT, get the part number of the mirror and it can be confirmed)
Where ever you see "Status: Cannot be reached 1100" that means its DEFINED in 19, but the system (not vagcom) cant talk to it. (this normally means its not there at all)
Where ever you see "Status: Malfunction 0010" that means VAGCOM can talk to the module, but the module is registering a fault. for some reason. For NAV/Radio 37/56 you will always get an error as its a retro fit without the correct diversity aerial system.
Now you have cleared the errors what are we showing from the system?
Post it up again and lets take a look.
Units can be recoded between regions but... i dont know IF thats why you have a fault for sirus.
You may need to check the coding still.
toot3954 said:
Thanks for the credit lol. It's nice to hear when posts you make come in handy [smiley=thumbsup.gif]
You're very welcome. I would have quoted your post, but I'm on Tapatalk and I coudn't seem to make it do it. Oh dear!
1 - 9 of 9 Posts
