1 - 6 of 6 Posts
Hi, well only had my tt just over a week and today a picture came up inte dash with loud beep.
It has mph with a circle around it and then a 1 outside the circle in the top left corner.
Does anyone know what's this means???
Thanks for any help you can give
Ian
its the speed reminder, i think you can set them to beep when you go over a certain speed, not having a owners book cant tell you how to turn it off, but there is a recent thread about it
T3RBO said:
To remove
Speed limit 1 is
Press the 'test' button for at least a second when car is moving above 5mph and it will clear
Speed limit 2 is
Ignition off, press 'test' button for 2 seconds, then with warning showing on DIS press and hold 'reset' button
T3RBO said:
To clarify...
Test button is the silver button on dash next to the clock
Reset button is the one located under the windscreen wiper stalk
1 - 6 of 6 Posts
