1 - 7 of 7 Posts
Hi guys
Just got this today
New strut brace ready to be fitted at the weekend
I will post some photos when I come to fit it
Phil :)
Takes some playing around with the wiring loom harness from the ECU which you need to be very careful about. Also you will find getting the wiper blades off can be a bit of a ball ache so pre soak the bolts in a penetrating fluid overnight. :)
Will this really achieve a lot? The standard structure between the strut tops seems pretty massive.
PS Just asking, not dissing. :)
Lol
Sorry photo from iPad so not that good also the carpet not that bad lol
Mckenzie thanks for the heads up I have ordered a wiper removal tool so hope will not be to bad.
As for me fitting it, I am doing ADI in October and hope will be on the track , just another thing to help with the day .
Red stuff pads being fitted at the week end to .
Phil :)
Sounds like your prepared then :) I had to go out and buy wiper tool as mine were well bonded on, found a bit of wd40 helped break the seal.
In regards to the outcome I imagine you will find the front is slightly sharper and more responsive to turn in. For the money it's a worth while mod I reckon.
Cheers mate
Yes hope they are not to bad to come off.
As for the strut brace When I had my cosworth I had one fitted so did a friend of mine.
He had some one go into is wing the brace stop the inner arch being push on to the turbo and engine
Every thing worked out ok and he got it all fixed but the body shop said with out it the car could of been a lot worse
Just though it may help if that happened to my tt
Phil
1 - 7 of 7 Posts
