OIL COOLER… What is needed???
Ok well now the mods have it about as far as the standard block and turbo can go.. (possibly a little bit further
) my attention is being focused on longevity of oil.. after recent discussions it's been adviced that a oil and filter change should be getting done around every 6k now.. (just to be on the safe side). So potentially hopefully looking for options to extend that to the current 9k regime… now I know a oil cooler increases oil life.. but weather I'll get a extra 3k out of it, we'll wait and see…. So as for the question.. WHAT IS NEEDED?
After having a look on WAK's website (thanks very much again) I managed to get the name of the parts he used on his kit. "Mocal" these guys are well into the racing scene and have been for many years.. unfortuntly there complete kit range does venture past Alfa for the A in the alphabet. So I've had to do abit of investigation.
Sandwich Plate
First thing is to find a sandwich plate, (instead of tapping the sump) a sandwich plate fits where the current oil filter fits, and allows for the oil filter to be fitted ontop of the sandwich (hense the name, sorry if this is teaching you how to suck eggs) Problem I am having is I do not know the thread sizes ect….of the filters. (is anyone aware and sure of the sizes????) I did however find this..
Assuming the info I've gathered is correct then the sandwich plate is infact this one:-
http://www.racerpartswholesale.com/product/1596/Mocal_Sandwich_Plate
Part No. MOC-SP1
Oil Cooler
Well to be fair I can't find any definitive answer on what size will fit where the standard TT intercooler fitted.. again WAK did get 2 oil coolers to find which one fitted best and looking at the pics I'm guessing they were a 13row and a 16row with the 16row being the one that fitted??? (again if anyone else or wak could confirm???) Also which fittings are used 8AH or 10AH… I'd imagine the 8AH is a lower circulation speed due to the narrower hoses, but maybe there is a issue with pressure… for the purpose of this post, and until I can get it confirmed I'm going to say we need to use a 10AH to be safe.
Assuming it is the 10AH and 16 Row cooler that's needed then I need to be ordering this:-
http://www.racerpartswholesale.com/product/4990/Mocal_235_Matrix_Oil_Coolers
Part No. MOC-16210
Fittings
Well again this hands on the 10AH or 8AH approach. Potentially need 10AH by my thoughts but obviously I am not running a oil cooler so guidance from someone who is would be great
Due to the location this will be fitted (where intercooler 2 is on the 225) then I've come to the conclusion that potentially one straight fitting, 2 90 degree fittings and one 45 degree (main reason for the 45 is if you fitted 2 90's they would come into contact unless you branch off at different angles (which won't look good)
So what is needed is:-
So that would be:-
1x MOC-TS-10
2 x MOC-T90-10
1 x MOC-T45-10
(although may well be worth getting 3 90's incase there isn't enough space in the bay)
Hoses
As for hoses, well these can be any sort, the do a stainless steel version also, but for the OEM look black is available
Therefore you would need:-
http://www.racerpartswholesale.com/product/2663/Mocal_Lightweight_Hose
Part No. MOC-AHL-10
Length. TBC
So I'm assuming that's it and we now have a TT oil cooler kit, the next question is what the demand with regards to extra oil.. I guess I need to do some calcs with the original sump.. the bore of the hoses and the capacity of the cooler to work out what amount of oil will be required during servicing.
Anyone in the know who can give a indication if this sounds about right????
Also now need to find a UK stockest, anyone know of good ones????
tony
Sandwich Plate
which was located here. http://www.car-stuff.com/carparts/auditt20002006framffph2870a1.html can anyone confirm??FRAM EXTRAGUARD OIL FILTER, ORANGE -- 4.92" Height, 3/4-16 Thread For audi TT 2000 - 2006
Part No. MOC-SP1
Oil Cooler
Part No. MOC-16210
Fittings
So that would be:-
1x MOC-TS-10
2 x MOC-T90-10
1 x MOC-T45-10
Hoses
Part No. MOC-AHL-10
Length. TBC
tony
