I've got a set of headlight inserts that I'm in the processing of spraying gloss black (not on my car). So far I have:
-Sanded/Keyed the plastic using 160 grit (in hindsight I think this may have been a bit to coarse?)
-Cleaned part using isopropyl alcohol
-Primed using grey plastic primer (about 3-4 coats)
- Let dry for 24 hrs
-Wet sanded using 1500 grit paper (too fine? I read 600grit is better for this?)
So far I am fairly happy with the results; although there are some faint lines from the keying, showing in the primer that I may go over again with the wet and dry (or will these be filled in slightly by the paint?).
Next I plan to:
-Wash part with water only and let dry.
-Apply 3-4 coats of gloss black paint
-Then 3-4 coats of lacquer
-Fit clear corners, ccfl and reassemble test headlight, hopefully with a big smile on my face! 8)
What I really want to know is if I am going about this the right way. Browsing the internet has brought up several different approaches, but what I'm looking for is a definitive guide/checklist for painting parts like this with spray cans - If I had a pound for every time I've read "It's all in the prep" without further clarification. [smiley=bomb.gif]
Also, I've sprayed parts before, but I only want to have to do this once, so I need it to look good, and want to do it myself.
Lastly, if you have any pics of gloss black headlight inserts please post them up, especially with clear corners on a dark green tt, I WOULD GREATLY APPRECIATE IT!!
Next I plan to:
