1 - 3 of 3 Posts
Hi all, I'm doing the rear ARB next weekend and will be needing a set of the single use bolts when I fit the new one - can I get them from any old motor factor e.g. GSF, what are they (part no / description etc)? Also what torque setting should I be doing them up to? It's an upgrade to a 16mm Golf 4Motion bar if that makes a difference.
Ditto for injector seals if you happen know!
Those parts are all dealer only, but they aren't very expensive.
Josh
Cheers man all sorted from the dealer - 79p
Any idea what torque on those rear ARB bolts? Anyone?
1 - 3 of 3 Posts
