1 - 6 of 6 Posts
I have to get my rear calipers refurbished as one is sticking very bad,
so I looked at getting my fitted calipers refurb'd, when I get an offer of some "256 calipers" now some searches show these as an upgrade VAG guys do, but are these the standard size I have (2000 225) or are these different, also I have seen post in the past about getting bigger disks for the back, has anyone any info on this?
Ta for any advice?
Hi Stub, TT 225 discs are 256mm x 22mm ventilated anyway, so not an upgrade as such.
I wouldn't put bigger discs on the rear, without bigger discs on front.
Stub said:
I have to get my rear calipers refurbished as one is sticking very bad, so I looked at getting my fitted calipers refurb'd.......?
Why not clean it yourself?
Had a sticky rear caliper on a Honda and it took a couple of attempts to fix, but after that it was fine for years.
Basically just fully extended the piston but gradually using wooden plates a bit at at a time to stop it falling out, clean piston with scotchbrite, and fine emery then grease using special grease that won't melt the rubber seal and work in and out a few times.
OK so 256 is standard, great info thanks,
so whats the max disk size i can use with these and what are people recommendations for disks and pads?
You can get 300mm disc kits from tarox and ECS that use the standard calipers
1 - 6 of 6 Posts
