1 - 4 of 4 Posts
Hi
Fitted the Blue-flame cat back over the weekend. The shop had to cut the heat shield to make it fit. Still getting a rattle so they have advised to remove the heat shield.
Is this ok?
jamman said:
Get under it and see if you can save/adjust it
if that fails
hit it with a hammer and bend it out the way
is that fails
Rip it off.
Hi
I watched the install and on the left (looking from behind) the top right panel was cut and pushed up but its a real snug, I can only imagine that the rattle is the heat shield. They said "We will probably just remove it" !!!
1 - 4 of 4 Posts
