The rear N/S rubber Jack point looking a bit chewed up. Can they be replaced? And if so, how easy/difficult is it to do?
Thanks.
Thanks.
8N0 804 583 | mounting for service lift | front and rear | 4 | |||
8N0 803 855 | mounting for service lift | front and rear | 4 |
Hi Hoggy, I get that there's a hard plastic bit that goes through the rubber puck, I can see that from underneath, but what holds the plastic bit? Seems like it goes through a hole in the floor?HI, They each come in 2 parts & are a press fit. One part presses into the other & holds it in place.
Part No.
Hoggy.
8N0 804 583 mounting for service lift front and rear 4 8N0 803 855 mounting for service lift front and rear 4 ![]()
Exactly the one that is going on mineI used one of mine recently and it crumbled, I think the oil from the haldex breather rots the rear passenger side mount.
