1 - 3 of 3 Posts
Hi Guys,
I bought my TT about 18 months ago and the previous owner had put the R badge next to the TT.
Someone has pulled the Red from the square that sits around the R :oops: and I was wondering if anyone has any advice on removing it as it now looks VERY cheap :(
Thanks,
Steve
I tried everything when I removed my crooked audi rings badge from the rear. The dental floss kept breaking on me and proved pretty useless. What did the trick in the end was using a hair dryer combined with pouring several helpings of near boiling water over the badge to soften the glue and squirting WD40 on the badge to aid the process.
Once the glue has softened, start to gently prise the badge away with your fingers. You may find that the badge ends up coming off in bits as it breaks up. Once it's off just T cut or otherwise polish out the mark where the badge was - it's usually just the residue of the glue.
1 - 3 of 3 Posts
