1 - 4 of 4 Posts
I had to take subframe bolts out both sides when I did mine, just do one side at a time. I put new subframe bolts back in as pretty sure these are one time use stretch bolts.
Same as Brian.
It is a monumental pain in the arse because, as Brian says, you “should” replace the subframe bolts as they are stretch bolts.
When confronted with that conundrum, I decided to go the whole hog, and dropped the subframes out and reconditioned them with uprated suspension and poly bushes, etc.
1 - 4 of 4 Posts
