hi,
after fitting the RNS-E (p/n ending 193D) previously concert unit
switched the aux pins to the grey plug, moved the bose pin
coded everything
seems like im getting the below fault code, everything works fine, FM quality is clear..
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Date: 2012.08.11
Time: 14:10:13
Freeze Frame:
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
apart from this fault code, i do get about the ZF antenna amplifier faults but ignoring that. What could i miss?
