41 - 60 of 83 Posts
Discussion Starter · #41 ·
spike said:
Looks something else to look at on Saturday :)
Lol, yeh there's a few bits
On iPhone using Tapacrap
Discussion Starter · #43 ·
Reverse camera depends on the stereo you have
Reverse sensors can be got cheap enough unless you want oem, then it's sensors, module and some wiring and coding
I've been to a members house in Coventry this morning lol
ReTTro fit said:
bimmerworx69 said:
anyone selling the lights pre modded?
I've got one left but it's promised to another member
If you can live without yours for a couple of days your welcome to send me yours and I'll mod it for you
ReTTro fit any chance you could do another one?
Pretty please ;)
Discussion Starter · #45 ·
Pretty please ;)
Pmd you
Discussion Starter · #46 ·
Anyone wanting this done please be aware that as blaylock as posted, the oem position and projectile of the LEDs is as per his pic
As long as your happy with the illumination in his pic then I'm happy to mod existing units
Discussion Starter · #48 ·
Yes mate I've also got a recessed led in my roof lining that I did when I first got the car
Discussion Starter · #50 ·
Looks better with all 3
Is the oem version of this very poor in the amount of light it lets out? I have the interior led pack and have the wee holes in the unit buy can honestly say I have never noticed them on, either the lights terrible, I'm unobservant or the bulbs are out :lol:
Just wonder did you solder the wiring for these direct to the pin outs on the pcb board?
Or did you splice into the incoming wiring?
Sent from my iPhone 6s using Tapatalk
Discussion Starter · #53 ·
Soldered to the pcb mate
May have to give this a go then!
Any chance of a cheeky pic of the led you have to light the gear stick?
ReTTro, can you show that 3rd LED you mentioned?
I also soldered it to the PCB. I soldered onto the connector pins right where they are soldered onto the board. If you are careful and don't use too much solder then you won't have any issues.
Sent from my XT1585 using Tapatalk
Discussion Starter · #57 ·
I used a normal 5mm led black bezel and recessed the led quiet far back into it so that the light wasn't visible once on
Found the best angle so the led aimed straight onto gear knob was in front of the courtesy unit
You have to really look for it in the black roof lining
Oh I like how you did that. I may have to copy the 3rd LED. The holders I have don't appear surface mount like yours. I would have to buy something more flat than mine.
Discussion Starter · #59 ·
3.2 V6
My car seems to have the holes there but with no LEDs behind them, is this normal?
Also, I plan to add them in, would you mind sharing how you wired them?
41 - 60 of 83 Posts
