To add to that, youd have to be a bit of a spanner with the Renovo products to get it wrong. It takes a bit of time and you need to have a couple of days of dry weather, but youd be hard pressed to balls it up.Jac-in-a-Box said:"Renovo" make hood colouring kits, really needa lot of care in use if you don't want to make a complete hash of your hood. I'd avoid using it
My advice is given after seeing the efforts of several customers best efforts at applying Renovo - a mess; both by my judgement and their admission...guess they're "spanners" for "ballsing it up" :roll:Snake TT said:To add to that, youd have to be a bit of a spanner with the Renovo products to get it wrong. It takes a bit of time and you need to have a couple of days of dry weather, but youd be hard pressed to balls it up.Jac-in-a-Box said:"Renovo" make hood colouring kits, really needa lot of care in use if you don't want to make a complete hash of your hood. I'd avoid using it
Id be amazed at how they turned out a mess, how is that even possible? :?Jac-in-a-Box said:My advice is given after seeing the efforts of several customers best efforts at applying Renovo - a mess; both by my judgement and their admission...guess they're "spanners" for "ballsing it up" :roll:Snake TT said:To add to that, youd have to be a bit of a spanner with the Renovo products to get it wrong. It takes a bit of time and you need to have a couple of days of dry weather, but youd be hard pressed to balls it up.Jac-in-a-Box said:"Renovo" make hood colouring kits, really needa lot of care in use if you don't want to make a complete hash of your hood. I'd avoid using it
If the guy wants a simple, inexpensive, effective and virtually foolproof method of resolving his problems, then in my limited experience I'd suggest he follows my advice :wink:
Dave
Go on then......Snake TT said:I can supply a pic of an impressively restored soft top 8)
Erm actually I cant because its p*ssing down. But as soon as I get some nice weather I'll post the results :wink:Adam TTR said:Go on then......Snake TT said:I can supply a pic of an impressively restored soft top 8)![]()
Glad you like Adam, I was very pleased with the results even tho the bad back that lasted 2 days afterwards made me say "Im never doing that again!" - I suppose thats what I get for sitting at a computer every day and not getting enough excercise :?Adam TTR said:wow, looks lovely.... ive got renovo here, gotta get round to doing mine
