1 - 9 of 9 Posts
When in 'D' coming up to a roundabout or corner with your foot off the accelerator it jerks abit when going from 4th to 3rd then from 3rd to 2nd. Is this normal?
nor mine
even on the paddles i can shift down a few times and there is only the very slightest jerk...
I LOVE IT!
if you touch the brake slightly, the stronic anticipates a down shift and it should then be without noticeable jerk.
but is this the case only while turning? that would be curious.
doesn't sound normal.
When your engine and drivetrain is fully warm - after say a 30 mile run, how do you find manoeuvring in 1st and reverse with a light throttle. Smooth or very, uh, unsmooth?
BLinky said:
is your transmittion mated properly to the engine? :?
ooo that sounds naughty!
on a serious note - does this happen after its been run in properly or a decent run to wamr everything up?
1 - 9 of 9 Posts
