1 - 3 of 3 Posts
Not had my aircon working for a few weeks now, checked fuses all seem OK and no fault showing through temp display. Had someone look at it and they have said that compressor is only working if manually overridden!! Had the problem diagnosed as a broken fan on front of car, been told that this should be running when aircon is switched on and it isn't!! Can anyone confirm this as I don't want to replace it if there is some other simple fault. The fan in question is on the right hand side as you look into the engine bay. The fan on the left is working.
1 - 3 of 3 Posts
