1 - 9 of 9 Posts
matty fitz said:
Hi there,
Can someone with a Bentley service manual please have a look though as see if it gives the proceduce of replacing the ABS pump/module and the re coding. I getting annoyed now and want to have a crack at it myself.
Matty
Matty
There is no ABS pump or unit replacement procedure in the Bentley manual, however, it does say this about the ABS hydraulic unit (N55) with ABS control module (J104)
Hydraulic unit consists of:
ABS hydraulic pump (V64)
*Do not separate hydraulic pump and valve block
*Check using diagnostic scan tool.
Thats it I'm afraid Matty...
matty fitz said:
Hi there,
Matty
It is in elsawin, if you pm me your email address can send you a Word format file as the procedure is quite lengthy. You will need Vagcom or VCDS to recode.
1 - 9 of 9 Posts
