1 - 20 of 39 Posts
Hi,
I'm looking to get spacers for the TT with the standard 18" 9 spoke alloys.
Does anyone have spacers with these alloys? Pic's please.
I'm thinking of 20mm at the back and 15mm at the front? or is that too much?
What are peoples thoughts?
Is there a certain brand i should go for? Don't really want to spend too much money on this.
B. :p
20 or 25 at the front (not sure, I've forgot :lol: ) and 30 at the back:
Edit:
whoops, didn't read that you need pics with 9 spokes
I went with 20mm rear and 15mm front spacers,bought from the TTshop,make are TPI bolt through.Excellent quality :D
Thanks for the replies, think i'm gonna go for 20mm rear and 15mm up front.
Has anyone heard of Hubcentric spacers? Are these any good or am i best getting H&R or Eibach? Price difference will be quite a bit i think.
ive got some 20 rear 15 fronts sitting at home waiting to go on.... but i think i need to wait till i lower it before they go on... may look a little wide and high :s
Won't look wide and high on post facelift ride height. Haven't seen spacers on pre facelift height to be honest.
I have 15 front and 20 rear on post facelift springs and it looks spot on.
Hubcentric is the type of spacer you need, not the make. If you buy plain spacers you will get wheel wobble, with Hubcentric (perfectly central to the hub) you won't get any wheel wobble :wink:
:oops: mines pre facelift, but the only thing i havnt changed is the height... i believe after 03 they dropped them 25mm? mins a 2000 [smiley=bigcry.gif]
Discussion Starter · #11 ·
Thanks, shows you how much i now :?
So has anyone bought spacers off ebay? Seen pairs for about £50 with bolts - is that about right and will they be decent?
I was thinking 15 rear and 10mm front with longer wheel bolts to suit I have a 2001 pre facelift car but dont want any chance of rubbing :!:
see ... rear
http://www.ebay.co.uk/itm/300723937770?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
front
http://www.ebay.co.uk/itm/150860193329?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
I tried 25 rear and 20 front but they rubbed so changed to 20 rear and 15 front...perfect now...
LordG71 said:
Hi B,
I have 20mm spacers all round, on Eibach springs. Full pics and comments in my thread
but here are a few to help:
LordG71
I have a pre facelift coupe with OEM springs
And was thinking about 20mm all round wheel spacers and saw this post
But have a couple of questions
(1) did you have to shorten your original wheel studs to use those spacers ?
(2) do the sides of the car get more dirty on wet muddy roads with the wheels out that far ?
(3) Where did you get the spacers saw these on eBay are they the same as yours ?
http://www.ebay.co.uk/itm/271024373426?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
(4) Do they improve the road holding handling in any noticeable way?
Thanks for your time :p
Stick to a good make spacer! They hold the wheels onto the car ;)
20mm rear 15mm front is the norm that people go for
I bought a set from the TT SHOP, not cheap but it comes with longer bolts including locking bolts, think they are 12 front and 15 rear, haven't fitted them yet as I'm awaiting my lowering springs and dampers to be delivered
OK sounds good KammyTT
What make & type do you recommend
The type that 20 mm longer bolts are needed and go straight through alloy concentric
Or
The steel concentric ones that have a set of 5 short bolts to hub and then you use your original bolts to the spacer
I don't know what's the best ???
I also have 20, 15mm back front and they are from the TTshop. The TPI spacers are really good.
I havent had both types of locating spacers so cant comment on best type im afraid.
1 - 20 of 39 Posts
