2012 TT Quattro S-line, WMI-HPA K04 Stage 2+, with OEM+ hardware
AbsolutelyDid you get new stretch bolts to go with your mounts?![]()
It's hard to say who ripping off who.
Personally I don't think there is a lot of R&D going on with any of the aftermarket parts manufacturers. Certainly not at the level or budget an auto manufacturer has access to.
Any company that has access to a CNC machine can crank out widgets, and not surprisingly widgets that look remarkably similar to each other... and to be truthful, the target market for aftermarket parts are peps who generally don't have a background in engineering, physics or auto mechanics so there is no problem selling theircrapwares (regardless of their value or 'effectiveness')
In the case of 034 vs CTS, replacing the fluid filled insert with a solid rubber bushing (using a factory housing) isn't a real leap in engineering. Maybe one hit the market before the other, BFD.
Can't see one company claiming that hours of research were 'stolen' based on that idea.
If anything both companies ripped off the engineer who designed the first fluid-filled damper and then want bragging-rights for "dumbing" it down.
Standard fitting is 1/8" NPT. NPT is a tapered thread, so it will never thread all the way in like a machine screw or similar type of thread.
According to the following doc I found @ https://www.nitrousexpress.com/images/Sno201.pdf
Page 6, Quote:
“Install the nozzle at a 90°angle to the direction of airflow, and so that the nozzle tip is flush with the inside of the intake tube or protruding slightly to ensure an uninterrupted spray pattern. Ensure the nozzles cone of spray has no obstructions near the mounting location.”
“Install the nozzle assembly into the threaded intake tube using E-6000 sealant on the nozzle threads.”
Page10, “Do not use Teflon tape or paste to seal connections. These sealers are not as effective as the E-6000 sealant provided and can break down over time with high methanol use, clogging components.”
@FNChaos I'm not following the code here. Are you saying that sitting flush is the best and only option for nozzle placement? If so I would agree, but my comment about having some depression being good for the spray pattern and atomization still stands. If you notice, my snow performance nozzles are already depressed, therefore even if the nozzle were to be flush the initial stream is still a few cm/mm behind the mounting wall. Please see this video to see two different conical spray patterns both sitting flush.The above mounting suggestion was for a Snow Performance system.
Page 12 of this AEM system states, ”In most instances, the air charge piping can be drilled and tapped for 1/8” NPT to directly mount the nozzle. If using thin walled tubing it’s suggested that a bung be welded to the piping. Mounting hole should be tapped deep enough to allow the end of the nozzle to be nearly flush with the interior of the intake once the nozzle is fully installed".
See: https://www.aemelectronics.com/site...thanol_Injection-No_Tank_InstructionsRevC.pdf
In both cases 'flush or nearly flush' is suggested. Guessing a flush mount will allow the maximum amount of pattern 'spread' and will not cause any turbulence or a 'dead-zone' behind the nozzle tip.
