Just going to say, you should look up the term "sunk cost fallacy" before being so sure of continuing down the same path using this reasoning. As I said before you're free to do what you want with your own car but just saying it's actually quite beneficial to understand the sunken cost fallacy, not just for this but for many other things.
I've had a K04 on my one car for about half it's life now (so nearly 5 years with it on and 50k+ kms). Never put a catch can on the car--never wanted to and never will.
Many others have run upgraded stages and turbos, without ever doing any catch can just the same. I've even been lucky enough
knocks on wood that my original PCV has never given me a problem despite being a common-failing part. I'm not sure how/why you're concluding that one "should" run a catch can at certain stages, but it is 100%
not necessary IME; but again you're free to "take away" and mod/equip your car as you see fit as said.
The other thing I worry about is that you haven't really diagnosed what's truly wrong with the car yet--is the turbo really an issue or is it fine, was the catch can responsible for the smoke out the back, is there some other problem, and what of the electrical issues with the cluster? Buying all these upgrade parts is all fine and dandy but what if you find out the engine needs to be rebuilt because of bad pistons/rings (which is a known problem on VL engines)? I was under the impression you wanted to keep this lower cost but seems like you've spent like $10k plus here just like that and still have to pay the labour for most of this stuff to go in (?), and still don't really know what issues the car had to start this all? Don't get me wrong, I spent my fair share of $$$ on my cars to be sure (and lots of people on here have spent many times more than me), but I am just a bit confused and I'm sure I can't be the only one of those that have followed along. This has turned from "I need to fix my car as it is smoking, could be a head gasket issue and wife is mad I'm spending so much on car" to "tune up" to "build thread, buying lots of parts!" over the course of a month or so.
Anyway, best of luck with everything. I see you have bought parts at SEM--they are good guys, bought stuff there too including my K04 & DP. I never had them do any work of course, but looks like they are quite competent a shop. If they are also doing the work on your car I think you're in good hands there. (I did also think you were not in the GTA but those are clearly pics of SEM in North York...) I can tell you that, presuming the car will be running fine, you will certainly
love the K04 once you get it on there. With that and the tune, the engine performance is like night/day over stock. The VL engine doesn't make quite the peak #s as the non-VL for various reasons, but it makes some ton of torque down low--very early in the rev range with a lot of "area under the curve". That along with all the other stuff you have lined up there should have you quite happy once it's all in/good
