Designed and manufactured in the UK without compromise to offer features and quality not found with other induction shields.
More images on instagram @dccustomwerx
Features:
Compatible with VAG ‘Group A’ platform models – VW Golf (Caddy)Mk4, Audi A3/TT Mk1, SEAT León/Toledo Mk1, Škoda Octavia Mk1.
Precision laser cut from 1.2mm brushed satin finish (DP1) 304 Grade stainless steel. Semi polished outer (engine side) aiding heat reflection.
Specifically, compatible with the RAMAIR® (Large) cone filter.
Compatible with most makes of cone filter.
Unique shape/design maximising the depth/volume available for the filter.
OE+ appearance that complements and aligns with adjacent OE trim/covers - replicates the OE air filter housing shape. Utilises the OE air filter housing mounting points - M6 stainless steel countersunk mounting screws and aluminium washers included.
Independent and slotted mounting brackets allow adjustment and provide a precise fit - without requiring force or spacers.
1.8 20vT and 3.2v6 engine compatibility. 88mmØ MAF aperture.
Pre-drilled mounting holes for 1.8T MAF. Stainless steel (black) M6 socket cap bolts, washers and locking nuts are included to secure MAF.
Finishing trim along top edge – can be removed if desired.
1062g approx.
Priced at £75 including UK shipping (tracked/insured).
