1 - 3 of 3 Posts
Hi all,after garage advice and the vag com codes,ive just replaced the maf sensor and the intake air temp sensor,and still have no turbo what so ever, they told me its a process of elimination and which could cost me a small fortune, which i don't have, so here,s the next step, thanks to Tony_rigby_uk,s reply, ill try the n75 valve which was a problem that he had whilst touring in Italy, if it works ill definitely be buying him a beer or two, ive also ordered a map sensor, which is an easy replacement and a boost pressure check in case a pipes split any other ideas are always appreciated and no its not a blown turbo . cheers kev ps i will be posting the fix at some point to try and help anyone else
N75 is defo a good bet
1 - 3 of 3 Posts
