1 - 18 of 18 Posts
I am running Yellow stuff with EBC brakes for over 3 cars now.
I think they work great... I drive a lot of AutoBahn in Germany and never had any issues with them.
Please explain why I should not go that way...
Iv found most EBC stuff to ware out pretty fast and as stated above, they create LOADS of dust. I recomend OMP pads if you can get some for those callipers. Don't know what people are using for the TT's though!
Jack
Discussion Starter · #15 ·
bluslc said:
DuTTchNL said:
18Z
disc are 345mm from mk5 r32
rears are 330mm
I got the 17z's I still want to use my 17 inch snow wheels..
330mm rear?? On standard calipers?
with standard calipers.. compbrakes 330mmx20mm
I want to go for the ECS Rear ones.. So I can match the 2 piece front rotors I want..
Rears are 2 piece on mine as well.[/quote]
I am using 334mm discs in front. So 330mm Comp would be to big for the rear
So I am going to use the 312mm ECS rear upgrade. That should work with the 334mm front
Keeping the balance a little bit
Keeping the balance a little bit[/quote]
that should work well..
1 - 18 of 18 Posts
