1 - 2 of 2 Posts
Hey all,
does anyone know what crank is used for the 2.0 stroker engine?? Also what length conrods are used?? I understand that the 1.8 blck is used as the bore is kept at 81.5 mm.
Any help info would be good, just looking at alternatives before possible rebuild.
paddy
Discussion Starter · #2 ·
G12MO X said:
82.5 mm bore and euro spec crank 92.8 stroke, just under 2l
Ah, got it now, never mind, thought it may have been possible to use a 2.0 ltr crank assembly & shorter conrods as an option.
Back to drawing board suppose!!
cheers for the info mate,
Paddy
1 - 2 of 2 Posts
