My TT suffered from the dreaded microswitch problem - including the alarm stuck permanently on - but I didn't have the time right at this moment to take the lock out and make up a replacement switch. As a temporary measure I therefore rigged up a simple toggle switch conveniently located at the quarter light and wired to two piggy-back connectors on the two wires to the microswitch, all done insitu. Now all I have to do is flick the switch when I open or close the door (it doesn't have to be simultaneous with the door closing). Good enough until I get round to replacing the microswitch.
However, this got me to thinking. All it needs is a simple bell push type switch which could be mounted either through the door frame metal or the door card to strike the car body somewhere - very much like the old courtesy light switch except fully isolated. Then its just a case of wiring it up in parallel with the two microswitch wires - no need to touch the lock.
I haven't come across any suitable switches yet, but maybe a forum contributor in the trade will know exactly what is needed.
