I'm having a few problems with the temps on my 2001 TTR 225. I have changed the thermostat, waterpump and temp sender but the temperature is still hanging around 100 (on the climate control unit). It sits at 100 and if i boot it it will maybe drop to 96 or 97, but cruising along it can get as high as 103, but when it does it tends to drop fairly quickly back down to 100.
This sounds too high to me, and further to this the engine management light has come on after only 40 miles since having the new parts fitted and the car is in safe mode again :? Not sure what else it could be since i've changed all the usual suspects (i thought maybe a piece of the old impellor was blocking a pipe, but the waterpump was only cracked and still intact).
Is there anyone in the Bournemouth area with VAGCOM? Don't mind paying. Anything else it could be that hasn't already been changed?
