So after much deliberation, I robbed the bank and fitted 4 new tyres to my TTS. Goodyear Eagle F1's, which came highly recommended on this forum.
Overall road noise is much better than the Conti's however, at speeds above 20mph, there is a terrible humming/tubular/tyre noise sort of along the lines of bearing noise without the rotational warbling associated with bearings. It started the day i got the tyres, but havnt driven much until today and its Piss**g me off.
Is this common?
Do you have this problem?
Will it quieten as the tyres wear?
Do I have room to complain and demand a different brand?
To eliminate bearing wear I have done the turning side to side at speed to see if it quietens off in one particular direction. Nothing! Equally before i arrived at the garage, no noise, so cant be bearings.
Advise would be greatly appreciated as always!
Is this common?
