Unless its removed i think it notes all tyre pressures on the underside of the pop up petrol cap cover.. im sure someone who knows of hand will be along to give you teh specifics thoughKentishTT said:Can anyone tell me the correct pressures please as it is not on the label on my car as it did not come with 18" wheels originally.
Cheers,
Kev
It does indeed note them there but not for 18" wheels as my car did not come with them and I guess they were not an option in 2001.ausTT said:Unless its removed i think it notes all tyre pressures on the underside of the pop up petrol cap cover.. im sure someone who knows of hand will be along to give you teh specifics thoughKentishTT said:Can anyone tell me the correct pressures please as it is not on the label on my car as it did not come with 18" wheels originally.
Cheers,
Kev
Thanks Iain, that's brilliant - part number and everything too [smiley=thumbsup.gif]forest said:Here you go Kev
Iain
On the front?ian222 said:36 seems a bit much to me, always put 31 in.
Would also stiffen-up side walls and help prevent pot-hole induced dents.KentishTT said:On the front?ian222 said:36 seems a bit much to me, always put 31 in.
Yes, will give a harder rise too.
However, I did run my previous set of tyres at 30/31 PSI all round and the rears were fine but the fronts got very worn on the outside.
A few more PSI would have given more even wear across the tyre width.
