Hi all,
I have been having very excessive inside front tyre wear.
A few weeks ago i was asking for possible wheel alignment centers in my area (London) that can be recommended but i didnt have any replys.
Anyway, i decide to go to a place today (Mrityre) and have my alignment sorted. The chap hooked the car up to the machine and then produced some figures that showed my front right toe was out (reading 0.28 degrees) and my front left camber was out (reading -0.16 degrees). He then told me that they had managed to sort the toe but could not sort the camber as you need to have a special tool from Audi to do that... is this true?
Does anyone here know much about wheel alignment? Im just wondering if the toe correction would have sorted my front inner tire wear before i go through another set of tyres [smiley=bigcry.gif] and thinking about it, as the camber that is out (which he couldnt adjust) is more positive then it should be (ie should have been approx -1.25 degrees) wouldnt this cause outside tire wear?
Is there any other suggestions for my inside front only tyre wear?
Can i get the camber checked? (any suggestions )
All help appreciated :?
