Hi everyone. Giving my thoughts on the new budget, no-name head unit installed over the weekend.
Head Unit:
Atoto SA102 Starter, £127, AliExpress (Italy), delivery in 7 days
Previous setup:
Standard Concert CD radio, amp with 9 speakers, non-Bose
Accessories:
I was planning on purchasing the CTKAU03, but found the component parts cheaper instead. So I got:
Connects2 CTSAD002.2 wiring loom, ebay £20
Connects2 CT23AU05 fascia and cage, £25
Twin fakra antenna adapter, ebay £5
Radio release keys, ebay £3
Already owned rear view camera (not fully fitted)
Already owned sub
Review:
I wanted a new HU as the Concert (understandably) felt dated, and lacked the connectivity of today's systems. The main thing I wanted was Android Auto, for maps, apps, calls and audio streaming. The cheapest branded units I could find online were JVC's around £300. The only reason I didn't buy such a unit was that they had no physical buttons, which I need as my car doesn't have a MFSW.
I naturally looked at the bewildering array of less well known brands on Amazon etc. but the reviews generally included both excellent, and poor - for the same unit, which kind of put me off.
I stumbled upon the Atoto brand on Amazon, and they sold the SA102 which has native support for Android Auto and Apple CarPlay, for £169. It has a row of physical buttons for volume, track, mute and home on the bottom. Reviews were the usual range, but mostly positive, and I watched a couple of YT videos to observe the speed of the interface, which looked good. I thought at this price, it's worth a punt. But in the end I cancelled the order, as I saw it on AliExpress for £127, shipping from Italy. So I bought that instead. It arrived in a week.
Fitted it over the weekend, and I must say I am very impressed. Sound quality is improved, especially at higher frequencies. I can now hear much more from the tweeters, which improves clarity to my ears. As I already fitted a sub, bass wasn't lacking even with the Concert. At first because of the difference, I thought the Atoto was on a boosted EQ or something, but no this was with a flat EQ, and without 'loudness' switched on. Loudness probably boosts bass and treble just a touch too much, so instead I've just tweaked the EQ a bit +/-1 or 2 dB. There are the usual pre-programmed EQ settings, plus 3 user settings. I can't remember how many frequencies are adjustable, but it's enough. 10 or 12? Also the sub volume can be auto or manually offset, and has an adjustable crossover.
It is louder than the Concert, as I used to have that turned up over halfway. For the equivalent volume in the Atoto I have it between a quarter to a third.
Android Auto works great. The phone needs to be connected by a cable though, which is a bit ugly but I can accept that. So far I have only tested maps, Spotify, TuneIn Radio and News. All work flawlessly, and the touchscreen is quite slick to use. It's capacitive and feels just like a normal glass screen, albeit slightly less responsive as you're controlling the phone. Because it's your phone, it shows real-time traffic etc., and maps are bang upto date. I don't have an iPhone so can't test CarPlay. The screen brightness automatically dims once the car lights are switched on.
I wanted DAB but this only has FM. Radio reception is excellent though. I used a twin fakra adapter, and had to trim one of the connectors to fit into the twin Audi socket.
Other functions I won't use are micro-SD slot, front USB socket and front AUX socket. It has a built-in mic on the unit, but this is overrided if you connect the supplied mic which can be positioned in the headlining or on the steering wheel cowl.
Installation:
The Atoto doesn't come with a cage. but is supplied with adjustable brackets for the sides. I didn't use these. Instead I used the Connects2 supplied cage and brackets. First thing to note is that the face plate of the Atoto is quite deep. Whilst it fits in the cage fine, its projection from the cage meant that the face of the Atoto would stick out in front of the Connects2 fascia - not good. I therefore decided to trim away the top and bottom of the cage by about 7 or 8mm, which allowed the Atoto to sit deeper into the cage. Easy job with tin snips.
It is supplied with 3 different harnesses: 2 with ISO connectors and 1 with bare wires. The difference between the 2 ISOs is the positions of the permanent and switched lives. I used connector B. It also has a video in / out harness that I didn't use, which can receive a front camera input, and output video to the rear of the headrests or whatever. No use in a TT.
I had already connected a sub using the un-used but live speaker outs from the Concert unit (a 3D printed connector that I friction fitted into the empty space in the quadlock) but I ditched this in favour of the standard RCAs that the Atoto has.
The Connects2 cage unfortunately didn't fit into the Audi aperture. Only by 1mm or so at each corner, so I had to file down the plastic in the Audi. Other than that everything was a doddle. Rear camera is wired up but sitting in the boot at the moment, pending sorting a route out to the back.
I've included a few pics of the installation and the unit powered up. Oh one final point - the thin bezel around the unit. Atoto provide 2 of these, but I used the Connects2 supplied one instead (they included 2 btw) The bezel wouldn't slide into the slot that you can see in most of the photos. It was just too tight a fit. In the end I filed 2 of the 4 tangs down slightly, which then allowed the bezel to slide in. As you can see, it's almost flush (the TT fascia is slightly curved so it'll never be totally flush) and you'll also see that the adjustment to the cage was absolutely necessary.
I wanted to upload a video to show boot-up speed, but mp4s aren't allowed. It's OK though I think - around 8 seconds from when the ignition is switched on until sound is heard.
Overall I am really happy with this unit. For £127 (+£7 postage) you can't go wrong. If anyone has any questions I'd be happy to answer them. And if I find any grumbles during use, I'll update this post.
