LOL! Matt, let's be honest, if I'd spent half as much as yourself on modding, I'd be bankrupt!Hark said:Not a clue mate, but sure Tony Rigby did a write up, both on here and in the last Mag.
On a side note have you found a small pot of gold and if so will we all be getting a share?
Cheers!Fictorious said:Front 225 - Single piston calipers, disc size 312mm
Front v6 - Twin piston calipers, disc size 334mm
Whether it's worthwhile or not is a question you can only answer yourself, but if you got them fairly cheap then sure.
Yeah well. I don't know about other people, but I have never been able to get any sense out of the search facility. I do a search for 'v6 brakes' and it just give me a few thousand posts that include v6 OR brakes, but not 'v6 brakes'. Using +v6 +brakes works no better. I've tried various iterations.GunnerGibson said:a simple search would have yielded a wealth of posts.
Tony Rigby, as stated above he did a great write up on here and in the TTOC mag as stated above. Now you have 4 choices.ttsteve said:Yeah well. I don't know about other people, but I have never been able to get any sense out of the search facility. I do a search for 'v6 brakes' and it just give me a few thousand posts that include v6 OR brakes, but not 'v6 brakes'. Using +v6 +brakes works no better. I've tried various iterations.GunnerGibson said:a simple search would have yielded a wealth of posts.
Surely someone has fitted V6 brakes to a 225? - or are they all too embarrassed to admit it?!
Les, right on all counts.les said:Tony Rigby, as stated above he did a great write up on here and in the TTOC mag as stated above. Now you have 4 choices.ttsteve said:Yeah well. I don't know about other people, but I have never been able to get any sense out of the search facility. I do a search for 'v6 brakes' and it just give me a few thousand posts that include v6 OR brakes, but not 'v6 brakes'. Using +v6 +brakes works no better. I've tried various iterations.GunnerGibson said:a simple search would have yielded a wealth of posts.
1/ Wait till somebody searches and finds his write up for you.
2/ Find it yourself.
3/ Join the TTOC and get the back issues of the mag or cadge a copy off somebody.
4/ PM tony.
The next meet we are both at mate, we'll do a side by side test. I'd be interested to see how the differ, if at all.tony_rigby_uk said:Also it has been said there as good as brembo juniours
Tony, that's brilliant, thanks. There's a wealth of useful info in that topic.tony_rigby_uk said:lol i'm Mentioned !! :wink:
http://www.********.co.uk/forum/viewtopic.php?f=2&t=146669&hilit=+How+to+R32
Some people say the standard breaks are fine... but i like the rest found that fade was a serious issue... and when you consider it's the same setup as a 180 when there remapped it's the next logical step...
Also it has been said there as good as brembo juniours (and would cost more than a juniour kit if new) good think is the disks are bigger... meaning pads are bigger... and doubble th pots of standard so breaking efficiency is much "Grab"...
Question i would ask is how are you finding your standards (which really depends on how you drive it) if you don't see a problem, then it's probably not worth it... however if you'vehad brake fade... when giving it sum... you should really look into this... (if you can get them cheap enough)
on a final note... breaks can only increase the chances of locking the wheels up... so make sure you got good tyres on also... especially in wet... mine are fine with the falkens..
hope that helps.
