1 - 5 of 5 Posts
got these vagcom codes and i have cleared them but keep coming back and carsrunning bit odd
can u help in the least expensive way possible !
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 AP
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 01236
TRUZZZ8N541016234 AUZ5Z0C9025144
4 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 01236
2 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
29-10 - Short to Ground - Intermittent
00779 - Outside Air Temp Sensor (G17)
Clean you maf and test for boost leaks that should take care of the first two codes . Normally bank one lean is a boost leak .
Said said clean your maf and see if you get code back if you do replace. Doing these two things may clear your camshaft code as well . Start with what I've told you and then go from there .
Hi, Disconnect MAF, if that cures running probs,replace MAF.
After a few starts/run, clear any faults again, hopefully they will stay away.
how do i do that please ?
1 - 5 of 5 Posts
