Last few sets so price dropped by £5 to clear them
I have a small number of clear vinyl sill protectors to save the door sills getting scratched as you get in and out had some fitted to my TTs from new and there have saved my sills from any amount of scratches when I have caught them with my shoes
Easy to fit just spray both the protector and sill with soapy ( use washing up liquid+ water ) water fit in position and squeegee flat on to the panel you can also use a hair dryer to if you need a bit of heat just to get a perfect fit at the top
Once fitted they can not been notice they are 55mm beep and run almost the full lenth of the sill below the door
£22.50 for a set of 2inc P+P
