CorrectJAAYDE said:Cheers John,
So with ET30's and 20mm spacer it will be like 25mm spacers on the rear with ET35 wheels right ?
Providing they are 8" wideYELLOW_TT said:CorrectJAAYDE said:Cheers John,
If my maths is right, then a 10" wheel with ET30 and a 20mm spacer will end up with it's inside face in exactly the same place at the stock 8" with ET35.JAAYDE said:Okay guys done some digging, i think the wheels are 10" wide.! Is this not possible to fit these ?
10" wide on the fronts too.. I'm guessing if i bolt them on with 10mm spacers on the front they will either stick out of touch my brakes !jbell said:I assume the 10" is just on the rear, if so just bolt them on, you need a 255/35 R18" tyre.
Much too wide on the front, you nees an 8.5 wide ET30 ideallyJAAYDE said:10" wide on the fronts too.. I'm guessing if i bolt them on with 10mm spacers on the front they will either stick out of touch my brakes !jbell said:I assume the 10" is just on the rear, if so just bolt them on, you need a 255/35 R18" tyre.
jbell said:Much too wide on the front, you nees an 8.5 wide ET30 ideallyJAAYDE said:10" wide on the fronts too.. I'm guessing if i bolt them on with 10mm spacers on the front they will either stick out of touch my brakes !jbell said:I assume the 10" is just on the rear, if so just bolt them on, you need a 255/35 R18" tyre.
