People have always been asking about what fits and what doesn't. I'm not a guru to say what will and what won't but here is what I have. Maybe it will help someone out when making decisions so why wouldn't I share.
The car and wheels:
Car specs: '00 TT Quattro Roadster, dropped with H&R suspensions lowering spring kit. Can't remember whether it was -30mm or -35mm drop.
Wheel specs: 19" Artec Turbo P 3-piece alloys.
Now this is where it gets a bit tricky. Since they are 3-piece wheels, I'm guessing someone has put them in pieces for polishing. The front ones have this data inside the center piece of the wheel. "10,0 J x 19H2 ET 44" The rear ones say "9 J x 19H2 ET 44". So based on this you might think that the front ones are wider than rear ones, but that isn't the case. I measured them because I was under impression my rear ones are either 10" or 10.5" wide and 265 tire really looks like a bit too narrow for the wheel. They actually proved to be 11" wide and front ones are just 10" wide.
They are with Porsche bolt pattern so I have 22mm adapters to make them fit the TT.
So, to clear it out the wheel specs
Front: 10x19" ET44 with 22 mm spacer adapters, 245/35-19 tire
Rear: 11x19" ET44 with 22 mm spacer adapters, 265/30-19 tire
They are a close call but they don't rub in normal driving situations. In a good bump while front wheels are turned more than ½ turn from steering wheel, they might scratch a bit on the front inner plastic fender/mud guard top screw. Even this might solve with different style screws and since it rubs really really rarely I haven't been thinking of it as an issue. 225 or even 235 tire on front should propably cure it also, but look a bit akward on 10" alloy.
Right then, I hope I have mixed up you all enough for now.
Feel free to ask or comment.
Mici
The car and wheels:
Mici
