1 - 7 of 7 Posts
Hi All,
Quick question -
what the best way to check the oil in a TTS.
i.e idle the engine from cold for 5 mins - turn off the check the dip stick?
Wait to oil reaches a certain temp then turn off - check dip stick?
Or drive car - stop then check dip stick?
Thanks in advance for your time.
Dave
Hi, With TT on level ground, once warm/hot engine shut down, wait 5 minutes for oil to drain back to sump, remove dipstick, wipe, reinsert & remove dipstick to check level. If adding oil, Don't overfill.
Never leave a cold engine idling.
Hark said:
Any difference doing it on a cold engine?
Hi, No real difference doing it on cold engine.
no - just let it drain to sump after a few minutes. You get false results checking too soon after switching engine off
I drive it into the garage after having been for a run, leave overnight and check in the morning
1 - 7 of 7 Posts
