1 - 3 of 3 Posts
Can anyone advise why I am getting condensation inside of my windscreen. This never used to happen previously.
How do I stop it from happening? Which seal needs replacement?
What function does the engine vaccum box have? Does performance get affected? Anyone have any pictures of where it sits?
have you been useing you're air con?
i try not to use it in winter,i use every now and then to run the compressor,always steams up for a couple of days after.
you either need to run it all the time or switch it off all the time.
however if you're carpets are wet then you will steam up
Yes I use the air-con / climate control pretty much most of the time iin the car regardless if its hot or cold...But this never used to happen previously - I have owned the car for 4+yrs now and its only started to occur... there must be something else to it.
1 - 3 of 3 Posts
