FAQ - VCDS Module 09-Central Electronics & Long Code Helper
17K views 14 replies 5 participants last post by  Jezzie
Posted from a German Spec 2007 3.2 Quattro Roadster -
I think it's safe to assume not all TT's have the exact same options in coding, so yours may be different. This is just to give you an idea of what may be available under the Centeral Electronics module and where to find it if you want to change anything.
My personal settings -
Byte 0 - Daytime Running Lights (Scandinavia) active. Like the North America option, it turns on the front DLRs. In addition, the tail lights and license plate lights also come on when the DRL switch is turned on at the master light-switch.
Byte 21 - Drop-down selection for 06 Bi-Xenon Front Light with LED Daytime Running Lights (DRL). This will allow you to replace the OEM DRL bulbs for LED bulbs without CANBUS error or the need to modify the wiring harness (in-line resistor).
Just so people know, this is a prefacelift module
And although it is a "High" module it is only a 24 byte which obviously gives less options etc
Here is a list of pre facelift cem modules
( note they are "8P0" which is from an A3, the TT didn't get its own )
8P0-907-279: 17 byte (base)
8P0-907-279-A: 17 Byte (Highend)
8P0-907-279-B: 21 bytes (base)
8P0-907-279-C: 21 Byte (Highend)
8P0-907-279-D: 17 Byte (Highend)
8P0-907-279-E: 23 byte (base)
8P0-907-279-F: 23 Byte (Highend)
*8P0-907-279-H: 24 Byte (Highend)*
8P0-907-279-J: 30 bytes (base)
8P0-907-279-K: 30 Byte (Highend)
8P0-907-279-L: 30 Byte (Highend)
8P0-907-279-M: 30 bytes (base)
8P0-907-279-N: 30 Byte (Highend)
8P0-907-279-P: 30 Byte (Highend)
8P0-907-279-Q: 30 Byte (Highend)
Firstly that's a different module, instruments has nothing to do with the cem
Needle sweep isn't just age related, also model related
MY11 onwards is available on any model
And just for info, needle sweep isn't done by the main 07 coding, it's an 10 adaption then it called staging
Ah, okay. Thanks! I assumed (wrongly) the needle sweep would have been listed under "Instruments" - thanks for the correction. For those that have it, under which module would it be located?
I'm currently going through all my blocks and adaption options to see what's there. I was also trying to see if there's an adaption requirement for the window regulator since Rip doesn't have a VCDS. I thought it might show up in mine somewhere.
In the case of wanting to turn off the headlight washers permanently, rather than changing the activation time to it's lowest value (50ms) it seems just going into the Long Coding and un-ticking the box at Byte 1, Bit 1 would do it.
I know it is an old thread, but for completeness needle sweep is in: 17 Instruments -> Adaptation -> Channel 36 'Special Functions I'
Not easily, would require a software update, followed by editing the EEPROM directly on the PCB, then the adaptation will be possible. So not very straightforward!
Thankfully, getting the rear lights to come on with the front DRLs is easy with VCDS -
Address 09-Central Electronics -> Byte 0 -> Bit 3: Daytime Running Lights (Scandinavia) active
Or with OBDeleven -
Control Units ->Central Electrics 09 ->Long Coding -> Byte 00, Hex 09 Daytime running lights (East Europa) 100%
Didn't allow you to do what?
Also note you have an MY10 which is a facelift car and should have the BCM. All the stuff above doesn't apply/will be completely different on a BCM car.
Do you have front DRL option...?
I have ordinary 21w filament bulbs fitted as drls - I don’t recall the full OBDeleven option list but I do remember the Scandinavian option was greyed out. (We did discuss this a few years ago.)
I probably didn’t have the led drl option available either or I would have tried it.
No worries - just remarking that depending on the car not all things are possible.
Jez
